Use this procedure to view the MACsec interface statistics using EDM.
  1. In the Device Physical View tab, select one or more ports for which you need to view the MACsec interface statistics.
    The switch supports MACsec on specific ports. For more information, see your hardware documentation.
  2. In the navigation pane, expand Edit > Port > General.
  3. Select the MACsec Interface Stats tab.
    Use the Clear Stats button to the clear MACsec interface statistics. The Clear Stats button is available to clear single-port as well as multiple-port MACsec interface statistics.
MACsec Interface Stats Field Descriptions
The following table describes the fields in the MACsec Interface Stats tab.
Field
Description
TxUntaggedPkts
Specifies the number of transmitted packets without the MAC security tag (SecTAG), with MACsec disabled on the interface.
TxTooLongPkts
Specifies the number of transmitted packets discarded because the packet length is greater than the maximum transmission unit (MTU) of the common port interface.
RxUntaggedPkts
Specifies the number of received packets without the MAC security tag (SecTAG), with MACsec not operating in strict mode.
RxNoTagPkts
Specifies the number of received packets without the MAC security tag (SecTAG), with MACsec operating in strict mode.
RxBadTagPkts
Specifies the number of received packets discarded with an invalid SecTAG, or with a zero value packet number (PN), or invalid Integrity Check Value (ICV).
RxUnknownSCIPkts
Specifies the number of packets received with an unknown secure channel identifier (SCI), and with MACsec not operating in strict mode.
RxNoSCIPkts
Specifies the number of packets received with an unknown secure channel identifier (SCI), and with MACsec operating in strict mode.
RxOverrunPkts
Specifies the number of packets discarded because the number of received packets exceeded the cryptographic performance capabilities.
